Low readings for compression test
Old Oct 14, 2010 | 12:30 PM
jakop92's Avatar
Default Low readings for compression test
Engine: d16y7
I tried two different testers, one was brand spanking new.
Results: 89 90 93 96 psi. The other tester showed about the same.
Now.. the car is running perfectly fine. It's not running rich nor is it burning oil or coolant. The odo shows 221k. I checked the blow by, since high mileage engines usually have a bit of blow by, but no smoke came out at all. The engine runs really good besides the low compression. Head gasket seems ok and I couldn't spot any leaks around the engine. The only problem I know of is a crack in the exhaust manifold right next to the primary o2 sensor.
I haven't tried a leak down test, but if I can get a hold of the tool to do so I'll def do it. What's could possibly be the culprit though (including internals)?
Old Oct 14, 2010 | 12:34 PM
98civdx's Avatar
Master Detailer
Default Re: Low readings for compression test
What kind of motor?
My car has low comp, runs fine. I don't really worry about it.
Usaly it is rings that cause that.
Old Oct 14, 2010 | 12:51 PM
jakop92's Avatar
Originally Posted by 98civdx
What kind of motor?
It's a d16y7. Shouldn't the readings be above 150psi?
I can see how it could be the rings. Man.. that's a lot of work to get to them though.
Old Oct 14, 2010 | 12:57 PM
nub's Avatar
nub
A couple things that could give low readings. Before testing engine should be brought to operating temp. Throttle should be held wide open while cranking during test. Your numbers are low but they are within the acceptable normal 10% variance. I would guess one of the two or both of the above were not done.
Old Oct 14, 2010 | 02:45 PM
jakop92's Avatar
Was not aware you are supposed to WOT during the test. I drove the car around for about 8min before testing to get it to operating temperature though. I'll try doing it while holding down the throttle.
Old Oct 14, 2010 | 03:13 PM
98civdx's Avatar
Master Detailer
ahh, yes that could explain your readings, redo the test and come back.
I have a y7 also, remember numbers for a this motor will be different from say a b series.
Im at around 210k, runs great other then a low idle. I wouldnt worry about it at all. Keep a eye on it, and keep her full of oil and you should be ok.
Rings are quite a bit of work, but noithing you couldnt do in your garage, other then going to the machine shop for a hone.
djsimm89
Jun 7, 2013 12:14 PM
Travis R
11
Jun 30, 2011 06:39 PM
dutchman5
Aug 5, 2004 02:58 PM
obd1gsr
Feb 18, 2004 07:58 AM
Andrew 825SM
Oct 19, 2002 10:05 PM
