H22 Dogbox? Any company still around?
Old Oct 14, 2010 | 12:22 PM
stunnerone23's Avatar
Default H22 Dogbox? Any company still around?
Ok so I am sick of going to the track only to have transmission problems everytime. I have replaced the master, slave, and bought a new m2a4 jdm h22 trans. The car will NOT go into gear at high rpms at all. Some guys have said to upgrade to a twin disk and get the ACT Clutch out of there. Is it the clutch or syncros that are my problem? I bought the Competition clutch twin disk and now wondering if I should go with a dogbox to eliminate my problems. I dont want to put the trans in only to pull it out again. The car made 674whp and 480torq. Will the clutch solve my problems or am I better off putting in a dogbox with it? No companies seem to be around anymore.
Thanks,
Mike
Old Oct 14, 2010 | 12:41 PM
90blackcrx's Avatar
Default Re: H22 Dogbox? Any company still around?
Mfactory and I was told ppg does.
Old Oct 14, 2010 | 12:54 PM
roadracer4life's Avatar
yea sounds like your having clutch issues and not trans issues.. Altho at the power level you are at i would suggest that you switch over to a dog box for better durability but if you are having shifting issues now i dont think they will get much better once you replace the trans with a dog box..
-sam
Old Oct 14, 2010 | 02:04 PM
crazes's Avatar
Moderator
from my understanding from the all motor guys is that the h trans doesn't like be shifted at high rpms at all. Thats why they have shifted to the b trans
yeah 1000 for me lol
Old Oct 14, 2010 | 02:13 PM
pellis90's Avatar
H seires trans not shifting at high rpm's is B. S. , just get your set up right. HINT ( Your shifter cables can't have any '' movement " and need to be solid ) You do not need to go to a dog box until you start breaking gears, and you will, then put a ppg in it and call it a day !! Tony @ T1 can hook you up, but the box is not cheap. The trans has been the best investment on our car so far.
Old Oct 14, 2010 | 02:26 PM
h22 civic's Avatar
yeaa ive been pondering this move also...i really dont want to ,the twin disc will make a difference ...i run the m2a4 with cc twin quaife and all new everything inside the case with carbon synchros and it made a huge difference
Old Oct 14, 2010 | 02:30 PM
2k.civic.si's Avatar
Thanks,
Mike
Based on this I would have the tranny built and put the new clutch in if you only want to pull the tranny once. At that power level you will break something in the stock tranny sooner or later.
Old Oct 14, 2010 | 03:19 PM
jnv255's Avatar
I run a PPG dog ( H series ). I got it thru bullhead gears.
I want to think Mfactory made a syncro set for H series.
As far as H series not being able to **** at Higb rpms... That's BS. I rev to around 10k, without doing the zip tie trick
Old Oct 18, 2010 | 11:50 AM
What exactly do you mean solid? I bought new honda oem cables and zip tied them every 3in going to the trans. I need a twin disk regardless I know that. I have adjusted the master more time than i can count too. Is it worth doing any upgrades to the stock m2a4 like syncros or run them oem as well? Just trying to get some solutions cuz its ridiculous how many times I go to the track only to be dissappointed. I run MT 24.5x9x13 et drags. The cars cuts low 1.6 60fts all day until 2nd gear comes and then its bad news lol so I dnt think its the slicks spinning either.
Old Oct 18, 2010 | 11:56 AM
Btw the turbo mani you made for me last year is amazing. It works well with my setup.
Thanks
Old Oct 18, 2010 | 12:13 PM
pellis90's Avatar
We never did syncro up grades, just ran stock trans., until the broke. You need to put the comp clutch you have in, that is what we are running right now and love it. What motor mounts are you running ? How does the trans feel driving around in the pits, Pop out of gear? resistance shifting at low rpm?
Old Oct 18, 2010 | 12:32 PM
DxTrix's Avatar
I agree the H trans not getting into gear at high rpm is bs. Shifting at 9500 rpm with 500 hp no problems but when the shift cables are bad u will have problems. My solution since my cars not a street car is I ran the cables straight through the fire wall on a stock m2b4 trans with a CM twin disk never been rebuilt. Zip ties also help to stiffen up the shifter. Thats my setup and it has been working like butter.
Old Oct 18, 2010 | 01:31 PM
2point6's Avatar
I used Liberty's face plated gearsets in my boxes. No synchros, mean that it is extremely difficult to miss-shift at high RPM.
Old Oct 18, 2010 | 01:44 PM
xenocron's Avatar
Does Liberty need fresh (un-used) gears to be able to face plate them?
Old Oct 18, 2010 | 01:46 PM
2point6's Avatar
No.
Old Oct 18, 2010 | 01:58 PM
xenocron's Avatar
Thank you, I had heard the opposite...
Old Oct 18, 2010 | 03:48 PM
90blackcrx's Avatar
Thanks
No problem man, any pics of the setup ?
Old Oct 18, 2010 | 04:52 PM
q16racer's Avatar
im hoping the twin disk fixes all my problems. If i launched and shifted at 6700 into 2nd, it wouldnt lock me out. But it always grinded 3rd around 8500. I'm running a comp twin, syncrotech syncros and new syncro sleeves.
mfactory sells a syncro kit for the H but it is made by syncrotech.
Old Oct 19, 2010 | 06:58 PM
Yeah I will take some when I get the motor back in the car for sure.
Old Oct 19, 2010 | 07:08 PM
It feels real notchy at low rpms. Im pretty sure it was due to my pressure plate. The fins are bent and the shift fork is twisted a little bit. Its probably from trying to jam it into gear when I destroyed the old trans. The old m2a4 lasted 2years and since I put the new one in from Hmotors Ive had nothing but problems. Im going to buy a new shift fork and put the twin disk in. I also have my cables ran through the firewall. The motor mounts are Hasport egh2. Never had it pop out of gear though.
Old Oct 20, 2010 | 07:53 AM
pellis90's Avatar
Put the twin disk in and fix the fork, and let us know from there.
Old Oct 20, 2010 | 03:05 PM
h22 civic's Avatar
what gear are you h22 guys going threw the quater in and what tranny/tire size?
Old Oct 20, 2010 | 06:49 PM
trickeng's Avatar
Sounds like you need to get your cables right (zip ties), you have a syncro issue and/or your clutch is not disengaging. take the tranny appart and check the syncro's. never had the plating done but it sound like a good idea. also, a cuff will definitely keep your tranny together longer.
Old Oct 20, 2010 | 07:17 PM
SPOOLINmatt's Avatar
Liberty face plating was the best thing i ever did back in 2009, if you send used gears they will clean them really well and scope them for cracks or excessive heat.
The best thing i ever did to my car was switch to a full dog box this year, its nice to not HOPE that its going in gear....I've had a CC twin for about 3 years now.
Old Oct 20, 2010 | 07:23 PM
2point2's Avatar
excuse my ignorance.. but what are the pro's/cons to faceplating? Is faceplating streetable?
BTW, I shifted my M2B4 at 8400 without any issues. ACT 4 puck. However, I wrecked a sleeve set and 2nd gear before I figured out that my clutch wasn't disengaging enough..
I've always wondered if the civic master has enough displacement...
