High pitched noise coming from 97 gsr?
Where is the noise coming from, is it there when engine is just running or does the car have to be moving?
Does noise "change" if engine RPM goes up or car speed increases?
Does noise "change" or go away if you step on the brake?
Does noise "change" or go away if you step on the clutch?
Is noise there in all gears, including reverse?
Any mods to the engine, like CAI or short ram AI?
What is the MM&Y the car, [model of Integra]? 94
97 gsr and sorry didn't specify where noise was coming from.
Coming from engine somewhere and I don't hear it upon start up but after the car has been running for a while I can hear it. Car doesn't have to be moving or in gear although the noise is constant regardless if you are in motion or not. Nothing seems to be wrong with the way it drives...just the noise
no mods all stock
no mods all stock
Check the alt., power steering, A/C compressor belts, make sure the are in good shape and at the proper tension.
Pop the hood and see if you can localize exactly where in the engine bay it is coming from. 94
