Exhaust Fabrication??
Old Oct 14, 2010 | 06:27 AM
C_Rock77's Avatar
Default Exhaust Fabrication??
I had a question about fabricating an exhaust. I'm looking at building a 3" exhaust for my project. I have a header with a 2.5" collector/flange. I'm considering using a pre-bent tubing kit, 2 resonators (no cat - running one in place of the cat), 3X6" flex pipe, and a muffler. How important is it to have a 2.5"-3" transition after my header? Would it be detrimental to just weld 3" tubing to a 2.5" flange w/o a transition? Should I run a 2.5" flange --> 2.5-3" transition --> 3" Flex pipe...., or is the transition even necessary? What would be your suggestion?
Old Oct 14, 2010 | 08:33 AM
Red_Army's Avatar
Default Re: Exhaust Fabrication??
i would say from what i know of flow(not much) you'd want a transistion to be about 4-6 inches of pipe. id run the transition then the rest of your setup.
but to be fair i do have a flex pipe shoved into my 2.75 collector and just welded in the 2.5 fp, but you do have that extra quarter inch.
Old Oct 15, 2010 | 01:24 AM
gstrudler's Avatar
That's actually the exact exhaust I am building currently as well. Right after the collector is probably debatable as a jump like that might appear to the manifold as somewhat of an "open" header (good for resonance effects), but it could also cause the exhaust gas to lose significant velocity when it encounters such a large volume change. I personally am going for a transition, but that would be an interesting comparison to run.
Old Oct 17, 2010 | 07:25 PM
C_Rock77's Avatar
Dave Stadulis (SMSP) recommended a transition. Considering his experience, I'd tend to go with his recommendation. I just thought I'd share his advice.
Originally Posted by SMSP
I assume you don't have a donut 2-1/2" joint and just a 2 or 3 bolt flat flange? If so then I would run a 2-1/2 x 3" taper into a flex pipe. If you have a donut joint then we could make a 2-1/2" x 3" flared taper with a floating flange and then you wouldn't need a flex pipe. What kind of header are you running?
Ef_CrazyCollin
Nov 24, 2012 01:42 AM
phoshyzzle
Jul 5, 2008 08:36 AM
jakscivic
Sep 9, 2006 02:07 AM
VanHonda
Apr 13, 2004 05:01 PM
xci_ed6
Aug 19, 2002 06:17 PM
