90 si with b16....idle problem.....need help
The car will idle fine, but if i let it warm up and i rev the motor it will want to die.
Sometimes it stumbles and goes back to a good idle and sometimes will die. Its annoying, when i come to a stop light it will try and die on me. Any suggestions?
If you are throwing the TPS code, then I would check that out for sure.. probably your problem right there. You can check it by getting a volt meter and testing the two of the three wires not sure of the colors. The two outside I think (not sure) but with the car on the on position test the voltage with the throttle body closed and you should get around 0.5v I think and when the throttle is fully opened you should get around 5.4v I think, if you aren't getting these values the TPS is probably gone..
410ruga
Mar 25, 2014 12:07 AM
