B17a in a crx, motor mounts needed??!.....
Old Sep 19, 2002 | 08:33 PM
russian_racer's Avatar
Default B17a in a crx, motor mounts needed??!.....
Is it possible to swap a b17a engine into a crx dx without buying different motor mounts or is it impossible?! THANX
Old Sep 19, 2002 | 08:35 PM
Trevor's Avatar
Default Re: B17a in a crx, motor mounts needed??!..... (russian_racer)
You will need b-series mounts. Like Hasport or place racing
check these out
http://www.hasport.com
http://www.placeracing.com
Old Sep 19, 2002 | 08:36 PM
wickedxboi's Avatar
i really doubt it. im running hcp mounts. your gonna have to use integra spindles and convert your dx to mpfi. hcp mounts are like 350-400. itll save alot of trouble and they work great.
Old Sep 19, 2002 | 08:53 PM
EP3_05's Avatar
It is possible to do without buying an aftermarket mount kit. You can have the mounts cut and re-welded in the correct position for the new motor. However, you will need to find someone that is very good at welding and has done it before. Because if the relocation is not good you are going to run into lots of problems. My suggestion is to just buy an aftermarket mount kit and save yourself the hassle.
iigrafixii
Feb 27, 2009 07:07 AM
SD1222
Feb 16, 2005 12:32 PM
CeeAreEx90
15
Jan 7, 2005 03:55 PM
crex23
Aug 8, 2003 08:11 PM
RavageEJ6
Dec 13, 2002 10:24 AM
