Been through 4 (7.5A) fuses in 1hr
Old Oct 13, 2010 | 04:50 PM
Importn2oRacer's Avatar
Icon3 Been through 4 (7.5A) fuses in 1hr
So my interior (courtesy light, dome light, map light) fuse went out randomly yesterday night. I bought some replacement 7.5A ones today and went through 4 of them already.
One thing to remember I've been having a complete LED lit interior for almost 3 years now.
The question is should I get a higher rated fuse or could there be something wrong with my wiring? I feel like this all happened after I blasted my music too loud, like as if the dual sub-woofers shook the car soo much that it short circuited a wire.
Old Oct 13, 2010 | 04:53 PM
SkRiBLaH's Avatar
Default Re: Been through 4 (7.5A) fuses in 1hr
just jam some copper in there with a fuse leading to some sort of TNT. im sure nothing will go wrong
Old Oct 13, 2010 | 05:47 PM
lol no seriously will a fuse with a higher amp rating help? I haven't tried it yet. I just miss my interior lighting up. It sucks having no light.
Old Oct 13, 2010 | 10:49 PM
MAD_MIKE's Avatar
MM Gruppe B
No. There is a problem with that circuit. Installing a larger fuse defeats the purpose of having a fuse. Locate the problem and fix it.
Old Oct 15, 2010 | 03:40 AM
CDdubz5's Avatar
what mad mike said. dont screw around. locate the short. you can under rate a fuse but never over rate it. ie use a 5A fuse if you need to but DO NOT use a 10A
Old Oct 15, 2010 | 03:53 AM
TheMuffinMan's Avatar
He knows where you live!
Installing a larger fuse will make it incredibly worse. Then you are allowing more power to flow through before it pops - which could result in an electrical fire or wires melting.
Old Oct 15, 2010 | 03:55 AM
CDdubz5's Avatar
it can also fry anything on the circuit.
Old Oct 15, 2010 | 09:13 AM
I fixed it, dome light wiring had a pinch, Thanks guys!
Ex-Eg-Driver
Sep 21, 2007 12:33 AM
Topnotcheez
Acura TL, RL & ZDX
Feb 20, 2007 06:04 AM
viva60
Nov 19, 2004 02:19 PM
SLOAZZ95
Oct 6, 2003 11:55 AM
