4 black relay like boxes, wtf are they
Old Oct 13, 2010 | 03:02 PM
94VTEC2TONE's Avatar
Default 4 black relay like boxes, wtf are they
i was doin some wire tucking and **** and came across the 2 black boxes like relays but heavily covered on the frame rail and then the wiring goes to the other side and theres 2 more that are heavily covered. wtf are they? i cut the first set not knowing like a fool but whats these things purposes? thanks
Old Oct 13, 2010 | 03:58 PM
fcm's Avatar
fcm
Old Fart
Default Re: 4 black relay like boxes, wtf are they
MM&Y of car would help.
"heavily covered" with what?
What color are the wires going to the "relays" and how many wires to each one?
Also, can you take a pic and post it? 94
Old Oct 13, 2010 | 04:19 PM
i believe there abs relays now that ive looked it up. They have a black cover over them, not like any relays ive seen but they are in the open so it makes sense. ill post pics tomororw
Old Oct 14, 2010 | 05:55 AM
fcm's Avatar
fcm
Old Fart
The ABS relay is incorporated into the "Electronic Brake Control Module" it is located behind right 1/4 trim panel on Integras.
Old Oct 14, 2010 | 07:04 PM
well idk that means. im talkin relays in the engine bay, nowhere near the trim panel dude
Old Oct 15, 2010 | 05:59 AM
fcm's Avatar
fcm
Old Fart
It means, the ABS relay is not in the engine bay, "i believe there abs relays" dude.
Take a pic and post it, it will give use a better idea of what you are looking at, there are more then a few relays in the engine bay.
The MM&Y of car is needed for use to help, for all we know you could be talking about a Ford, I assume it is a 94 Honda of some sort because of your screen name, but then again you would not be the first poster to be talking about some other MM&Y of car.
More info, MM&Y, where on frame rail, " heavily covered" with what, wire colors and number of wires into each "relay" and a pic would be even better. 94
NorthernXposure
Feb 17, 2008 04:17 PM
NorthernXposure
Sep 20, 2007 12:02 PM
M2B4
Oct 18, 2006 07:46 PM
axtran
Jan 25, 2006 10:23 AM
