Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 crv 4wd Horn problem
Old Oct 13, 2010 | 11:14 AM
zapper36853's Avatar
Default 2000 crv 4wd Horn problem
I'm having a problem with my horns. I have no horn whatsoever. I've disconnected the horns and tested them by grounding and running off the battery. One horn works and one does not. Can one horn not working, cause both horns to fail. My fuse has been checked and is O.K. I'm also reading a lot about a horn relay, I can't find one, exactly where is it located. When I start the car and push the horn button, I hear nothing. No relay clicking. Also the SRS light is off when the car is running. I would appreciate any solutions to my problem.
Old Oct 14, 2010 | 04:54 AM
Boosted Power's Avatar
Default Re: 2000 crv 4wd Horn problem
Cruise control work?
Could be that you have a bad clockspring?
One horn not working shouldn't cause both horns to not work.
Old Oct 14, 2010 | 07:03 AM
I have not checked the cruise control, but as soon as I do I will re post. Thank you for your help.
Old Oct 14, 2010 | 11:14 AM
The cruise control works fine. So I'm thinking horn relay. Any ideas would be appreciated.
hfsb
Apr 1, 2019 10:36 AM
PhillyB16
Apr 29, 2008 08:02 PM
adas
Mar 27, 2007 04:19 PM
ITR43
Feb 12, 2006 02:27 PM
Pengo
May 16, 2002 07:29 AM
