88 civic no start.
Old Oct 13, 2010 | 09:13 AM
jester1614's Avatar
Default 88 civic no start.
I have an 88 civic with a d16y7 that lost spark suddenly yesterday. I had the car at home to fix a hole in the exhaust (temp fix). i had to run the car for 20 minutes. the car started to overheat due to the fans not coming on, so i shut the car off and started looking into finding the coolant temp sensor. I found a few things that were unplugged so i plugged them in. one was a single bullet prong sensor high up on the cylinder head. the other was a single bullet style sensor on the rear of the motor above the oil filter.
went to turn on the car and vehicle will not start. it is getting no spark coming out of the cap. cap is good rotor is good. I was told that it might be the main relay so i replaced that (origonal had a burnt electrical smell) installed the new one no change in symptoms, and now the new one smells burnt. so either i fried the new one or it isnt the problem.
Check engine light does not turn off in koeo, and the obd1 pr4 with the red led does not flash to check codes. Do i need to jumper anything on it for it to flash codes?
any other ideas?
can the coil be tested? if so how
Old Oct 13, 2010 | 09:17 AM
jester1614's Avatar
Default Re: 88 civic no start.
oh i also jumpered the 2 pin sensor on the head by the thermostat housing. i thought it was the coolant temp switch
Old Oct 13, 2010 | 09:31 AM
jester1614's Avatar
also all fuses check out as good
Old Oct 13, 2010 | 10:08 AM
Laserjock's Avatar
It turns over? Can you hear fuel pump prime? Smell gas in the combustion chamber?
check the Hazard fuse (10 or 15A?) in the engine compartment for the no LED ECU?
The coil can be teste but is very involved.
Old Oct 13, 2010 | 12:06 PM
jester1614's Avatar
well i started pulling parts and the ecu is fried extra crispy
aznjay510
Apr 29, 2019 08:13 AM
Dtmk69
Jan 5, 2016 10:27 AM
barbourjay
Feb 24, 2007 01:44 PM
keng
22
Jan 18, 2004 07:43 PM
annointed
Dec 19, 2003 01:03 PM
