Master cylinder leak.
Ok i replaced my master cylinder about a month ago, there is a leak but i cannot locate it, anyone know what i should start replacing to get this problem fixed? ( i have a 96 h23 and i am a super noob ) =]
Looking back and forth in a "searching" motion... lol.
seriously tho.. can't really help you find the leak from a computer you have to just poke around. How do you know its leaking? I bet its leaking on your foot isnt it...
There are only a couple places it could be, i would start with checking to see if the hoses on the cylinder are tight and are not leaking. take some paper towels, fold them up and place under the Master cylinder and drive around for a bit... if its wet then.. there ya go.
yea i realize theres only so much you can tell me, i just cant afford to bring it to a shop right now. but i will try that and see how it goes, thank yaz
switch around your logic, you need to find out what needs replacing then replace it, not just starting parts blindly until it is fixed. If you give us more details about the leak we could diagnose the problem for you.
Usually I look at the top of the pedal inside of the car or around the cylinder seals under the hood. It should still be wet or eaten away some paint depending on where it is leaking from.
check the hose that goes to the Master cylinder. The clamp on there sometimes will leak, even if you think it's tight. I'd replace the clamp. Check the slave cylinder bleeder valve, make sure it's closed, (but not too tight)
More than likely the hose from the reservoir or the seal for the push rod. If its the push rod then you just get on the floor on the driver side and look up at where the rod comes through the firewall and connects to the pedal, it will be wet. The line is simple, it'll just be wet more than likely on the master cylinder side.
