any advice before installing my clutch and tranny
Old Oct 12, 2010 | 05:27 PM
dc2LS's Avatar
Default any advice before installing my clutch and tranny
I already pulled everything out im taking the flywheel to the machine shop tomorrow.this is my first time doing a clutch job any advice before i assemble everything togheter like exactly how he trowout bearing should be positioned etc.I did a cable clutch many years ago but have never worked on a hydro tranny any info is greatly appreciated.
Old Oct 13, 2010 | 07:28 AM
dc2LS's Avatar
Default Re: any advice before installing my clutch and tranny
bump
Old Oct 13, 2010 | 08:36 AM
shocker911's Avatar
its pretty straight forward....make sure you put flywheel on the right way...then i wipe it dwn with brake cleaner then put in alignment tool then clutch disc then pressure plate. Torque dwn bolts then put on trans
Old Oct 13, 2010 | 09:38 AM
mvang001's Avatar
This is probably your best time to upgrade your flywheel bolts to some ARPs if you want. Also, if you bought an XTD clutch or F1 racing clutch, b ready to do a clutch job again soon..
Old Oct 13, 2010 | 11:22 AM
mouab18c1's Avatar
Depends. I've seen some that lasted a few years and some that shitted within months.
Old Oct 13, 2010 | 12:24 PM
dntnedvtec's Avatar
So true.
I used the old bolts with red thread locker.
Old Oct 13, 2010 | 06:04 PM
Integra4lyfe069's Avatar
red..?
red u need heat to come offf
88 EF Hatch
Oct 7, 2009 10:39 AM
m015094
Feb 19, 2007 11:44 AM
SSJSubgeta
Oct 22, 2005 12:20 PM
Jays91DXhatch
Feb 14, 2004 04:00 PM
