GSR Intake Mani extended stud Question.
Old Oct 12, 2010 | 05:24 PM
nus_dogg's Avatar
Default GSR Intake Mani extended stud Question.
I searched and found nothing and did found a few threads about GSR Skunk2 Pro IM and Hondata IM gasket which will require you to get longer IM studs.
So a buddy from another forum told me to get 8x35mm(Honda part#: 92900-08035-1B) which are suppose to be longer; since, the original studs on the JDM GSR head are 8x25mm.
My question is, will the stock original 8x1.25mm nuts work with the extended studs(8x35mm)? I'm thinking it should since both are 8mm in diameter. But just not sure cause I don't know the thread pitch on the IM nuts from the GSR head.
Old Oct 15, 2010 | 07:38 PM
IntegraKid_88's Avatar
Default Re: GSR Intake Mani extended stud Question.
Ive read about using throttle body studs (which may be the part number you listed) if i remember correctly they used the hondata with an OEM gasket on either side.
Old Oct 15, 2010 | 09:07 PM
NotAJDMFanBoy's Avatar
I made my own cometic intake gasket out of a sheet of 1/8" PTFE and just smeared a very thin layer of RTV on either side. It will deform slightly on it's own, but added the RTV as extra insurance. Stock studs worked with my USDM head and eBay "ITR" intake.
sleeper_92
Dec 12, 2012 01:26 PM
Mad Money
Jun 19, 2006 04:17 PM
jaystation
Jul 23, 2005 04:54 AM
hatchattak
Aug 11, 2004 09:48 AM
B18C2_sedan
15
Mar 7, 2004 11:17 PM
