quick question about skunk 2 manifold
Old Oct 12, 2010 | 05:05 PM
sc34dc4's Avatar
Default quick question about skunk 2 manifold
I've searched and keep seeing conflicting answers. Please only respond if you have a real experience with this. I don't want "well it should fit' answers. Don't want to waste money if I don't have to. Ok so on with the question.
I have an LS integra and I'm sticking my built GSR motor in it. I'm using a skunk 2 intake manifold and stock LS throttle body. Will I need to get the itr throttle cable and bracket or just the bracket or neither? I've read the ls cable will work fine but the bracket won't Thanks,Adam
Old Oct 13, 2010 | 01:28 PM
sc34dc4's Avatar
Default Re: quick question about skunk 2 manifold
Anyone?
Old Oct 13, 2010 | 02:34 PM
racebum's Avatar
mmm...the ls bracket should work with that TB. worst case the itr bracket and cable are only 25 for both. the ls and itr cables shouldn't be that much different.
Old Oct 13, 2010 | 03:34 PM
sc34dc4's Avatar
Cheapest I've found them is like 35-40. Bracket is like 9 but after s&h it's 17. If I just need the bracket I'm ok with that.
Old Oct 13, 2010 | 04:00 PM
racebum's Avatar
the bracket is literally a bent piece of metal the cable sets in. i think dealer list at your local acura dealer is under 17. i bought the itr cable and bracket in a large order for 25-30 if i remember right but it was acuraoemparts.com which is good place to go if you order a lot. on small orders the shipping kills you. still your ls bracket should work if it sets on the skunk manifold. if it all lines up you'll have enough adjustment in the cable. personally i would try what you have. fairly sure it will work as is
keebs
Jan 24, 2008 05:45 PM
type Gendy
Mar 21, 2006 05:30 AM
JDM00SI
Jan 22, 2006 02:06 PM
STG3PWR
Feb 19, 2005 08:27 PM
93gsrcoupe
Jan 20, 2005 09:14 PM
