Toyo Extensa HP Tires
Anyone have experience with these?
I want to give them a try but I'm not sure they will be adequate for the winter.
It's either the Toyo tires or Kumho ASX tires which tend to last about 10k.
I'd rather stay in this price range as I bought a relatively expensive set of BFGs a little while ago and they only lasted for 12k even tho the warranty said 50k iirc.
Application is a mostly stock gsr.
Thanks
Thanks
I don't have any experience with those, but the Kumho ASX should last you much, much longer than 10K miles. The ASX comes with a warranty for 30,000 miles and should last most people significantly more than that.
If you only got 10K miles on tires that came with a 50K warranty, then unless you're doing constant burnouts, there's something wrong with your car. The most likely culprit is the alignment (especially the toe) but you should get the entire suspension checked out for other problems (bent components, etc).
chiquito
Honda Civic (2006 - 2015)
13
Apr 14, 2008 12:18 PM
