i need help with 89 wagovan
Old Oct 12, 2010 | 02:46 PM
89jdmwagovan's Avatar
Icon2 i need help with 89 wagovan
ok so i bought my 89 wagovan with a b18b1 swap in it. it wasnt running and what i was told was that all it needed was the alternator put back on and a new battery, i did all that and it still wont turn on. the car will crank but wont start. i just found out that the ecu was a pr4 a60. the wire harness has been cut and taped poorly so im not sure what the problem is anymore if anyone has any advice on that i should try or what i need to get it running please let me know thanks for reading
Old Oct 12, 2010 | 02:53 PM
Domnificent's Avatar
Default Re: i need help with 89 wagovan
mabe if you post pics of your wagon... we can tell you what the issue is..
Old Oct 12, 2010 | 03:32 PM
brettj20's Avatar
did you check for spark? or are you getting fuel? does the fuel pump kick on when you turn the key.
Old Oct 12, 2010 | 03:56 PM
EE2bitsk's Avatar
maybe that?
FLA$HY_5SiX2
Nov 8, 2011 02:57 AM
k_vd16
Feb 5, 2011 01:42 PM
tico
Aug 22, 2006 02:32 PM
Hybrid CRX
Jan 9, 2004 08:17 PM
