burning oil smell!???
Old Sep 19, 2002 | 07:40 PM
GsrSdn's Avatar
Default burning oil smell!???
Well..like the title says..I have no clue whats wrong but for the last week and a half ive had a terrbile smell inside my car everytime I drive. anyone have an idea what it could be, i checked for leaks and couldnt find any? only smells inside the car cant smell anything outside. anyone.!?!?
Old Sep 19, 2002 | 09:47 PM
hoya_10fintec's Avatar
Default Re: burning oil smell!??? (GsrSdn)
try compression test...
Old Sep 20, 2002 | 08:02 PM
3rdGteg's Avatar
Default Re: burning oil smell!??? (hoya_10fintec)
Getting any blue-grey smoke and oil burning smell out of your tailpipe? If so and no external leaks, you're burning the oil in your combustion chamber which lead to signs of worn piston rings or valve guide seals.
Old Sep 21, 2002 | 07:08 AM
TimoneX's Avatar
New User
Default Re: burning oil smell!??? (3rdGteg)
What they said. How many miles on there? Hard miles? Lotsa city driving, uphill battling, or sandy dusty dry environment?
Old Sep 21, 2002 | 09:31 AM
GsrSdn's Avatar
Default Re: burning oil smell!??? (TimoneX)
118k miles, ive had it since around 106. I guess you could say the miles i put one were somewhat hard. I checked for leaks and couldnt find any. I also checked for anything rubbing or something that could be burning. I found nothing. So what now? any way to see if the piston wrings are bad without taking the eng. apart?
Old Sep 21, 2002 | 10:06 AM
TimoneX's Avatar
New User
Yes. Do a compression test. If you can't then have someone do one. Or if they have the toys have them do a leakdown test.
Old Sep 21, 2002 | 03:06 PM
Mr. Choi's Avatar
New User
im wondering, did you do an oil change jus before the smell? if you did you jus spilt oil on your exhaust or block, or both. if you get some bluish smoke when acceleration your compression rings are leaking. if you get some smoke while decelerating your oil rings are going bad.
Old Sep 21, 2002 | 03:17 PM
myhatchrips's Avatar
start off with a compression test. the readings should be within 20% percent of the highest reading. to further diagnose the problem do a wet compression test to see how well the rings are seating. if one or more cylinders are lower than the rest pour a teaspoon of oil in that cylinder and do the compression check. if the compression goes up, then your rings are shot. if it doesnt change at all then your valve guide seals may be toast. take note of the reading on the first crank during the compression test. that tells you how well your rings are seating. first and last readings are the most important. hope that helps. if not then your wrist pins may have scored your cylinder walls during high revs and high temperatures. peace
Old Sep 21, 2002 | 04:15 PM
Michael Delaney's Avatar
you sure it isn't the clutch?
Old Sep 21, 2002 | 04:57 PM
xcutebabex's Avatar
Default Re: burning oil smell!??? (Michael Delaney)
damn looks like ive got a bunch of **** to do....i dont think its the clutch, dosent smell like it..although my clutch is starting to slip some.
EDIT: woops my g/f was logged in thought it was my name.
[Modified by xcutebabex, 1:58 AM 9/22/2002]
Old Sep 22, 2002 | 08:54 AM
RallySportCivic's Avatar
Default Re: burning oil smell!??? (xcutebabex)
same thing went wrong with mine, it is a small leak, do you have an oil pressure guage? cheack the line in the back of the engine it may be loose.
Old Sep 22, 2002 | 04:23 PM
that's a good point, too... when my clutch was going bad, i thought someone in my car kept farting...
Ci-v-iC
Aug 13, 2011 11:17 AM
prionailurus
13
Feb 19, 2008 07:36 PM
andyt
Feb 3, 2006 07:26 AM
Tony_EM1
May 26, 2005 10:34 PM
AMChev
Sep 15, 2002 10:26 AM
