Sport Max 002 question please help
I have a 95 del sol and I want to get the sport max 002 wheels 15x8x0..
right now I have stock 14's lowered on skunk2 coil overs and Ive seen some
cars that have the sport max wheels but they stick out past the fender about a inch or more, if i buy a camber kit for the front and rear, will I be able to cuff
the tires and lower my car without and tire sticking out past the fender??
please let me know what I can do THANKS!
that is weird..the shop that has the sport max's, the guy said that I would have to put a camber kit in the rear and roll my fenders in the front but I seen a sick *** white del sol
that has them and all it looks like is that he has a camber kit in the front and rear...
https://honda-tech.com/forums/showth...3#post43753573
15x8 is too wide for the tire size you need for your del sol (either 195/50-15 or 205/50-15, depending on which model you have). Don't get anything wider than 15x7.
Yup. Also, you're deciding things backwards. You should FIRST find out the best tire size for your car, and THEN find out what width wheels they can be mounted on.
If your car is a 1995 del sol VTEC, then get 205/50-15. If it's a 1995 del sol S or 1995 del sol Si, then get 195/50-15. And neither one should be mounted on 15x8 wheels; the maximum width is 15x7.5 for the 205/50-15, 15x7 for the 195/50-15.
