b20vtec: Spark plug gap 0.22?
Old Oct 11, 2010 | 03:06 PM
thisboyjulio's Avatar
Default b20vtec: Spark plug gap 0.22?
Running ngk R bkr6e-11 removed plug the gap was at about 0.22 is this normal or do you thank piston is hitting the spark plug ??? Please help b20vtec I believe normal gap is .44 to when removed was at about .22-.25
Old Oct 11, 2010 | 03:31 PM
Former User's Avatar
Default Re: b20vtec: Spark plug gap 0.22?
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Old Oct 11, 2010 | 03:32 PM
Pothole987's Avatar
try regaping them. they problaly weren't gapped properly anyways.
Old Oct 11, 2010 | 04:04 PM
93egSLEEPER's Avatar
NGK's need to be gapped before installed. They come from the factory gapped at .22-.25 Regap them, run it, and check the gap again.
Old Oct 11, 2010 | 06:11 PM
from the factory from ngk they come .44 what do you think would be the proper gap for all motor b20 vtec.
Old Oct 11, 2010 | 06:14 PM
I find this a bit strange...all the NGK's I have ever run I had to gap to .40
Gap yours to .40
Old Oct 11, 2010 | 06:30 PM
.40 for all motor b20vtec ?? whats the diffrence in gapping? from .40 to .44 or .22-.25
should the gap be smaller or bigger on a all motor?
Old Oct 11, 2010 | 06:42 PM
I gapped my poorman R at .40 and its running 11.5:1 compression.
Whats the specs of your motor?
nitewolf
Aug 15, 2010 12:56 PM
importimage
Apr 22, 2004 04:31 PM
