Z6 won't idle when cold and idles high when hot after throttle body installation
Old Oct 11, 2010 | 12:47 PM
rollinhonda3's Avatar
Default Z6 won't idle when cold and idles high when hot after throttle body installation
i recently picked up a 95 4dr civic ferio with a fresh rebuilt z6 swap with a y8 skunk2 intake mani 4-2-1 headers blah blah all that is un needed info but my problem is when i got it the kid gave me an extra throttle body because he put a b16 one on there and the tps is shot so it idled a lil high but ran fine so i went to switch em out but the new one had a shitty ficv on it so i just put the old one back and put everything back how it was and now all of a sudden it wont idle at all on start up and idles at like 150-200rpms after warm up and i messed with the throttle set screw and stuff already and 200 is the highest i got with it all the way out im tempted to just sell it but i really dont wanna can anyone help maybe had this problem before it also could be off time because the kid didnt tighten the crank pulley bolt or somethin and it shot off while i was driving the other day but ima check that so any suggestion minus the timing part idk for sure if its off havnt looked but gonna check it out!
Old Oct 11, 2010 | 01:04 PM
hatchaddict01's Avatar
Default Re: Z6 HELP!!
check to make sure the tps and the map sensor plugs arnt switched cause they will plug into one another and they are both on the tb
Old Oct 11, 2010 | 01:28 PM
Former User's Avatar
Default Re: Z6 won't idle when cold and idles high when hot after throttle body installation
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Any CEL codes?
DDY_EGC
Apr 2, 2019 05:52 PM
Leviatard
18
Oct 30, 2014 09:28 AM
snatch
40
Mar 29, 2011 01:25 PM
mistahmac
14
May 28, 2009 02:18 PM
gnar kill
Dec 5, 2005 02:19 PM
