need help picking cam shafts!!!!
Old Oct 10, 2010 | 09:32 PM
honaker510's Avatar
Icon2 need help picking cam shafts!!!!
ok i just got a stock 91 integra ls and i want to get a little more power. my friend told me to get new cam shafts and it will help with a little better performance and speed. Can someone help me pick a stage 1 shaft or tell me some other things to do?
Old Oct 10, 2010 | 10:47 PM
mouab18c1's Avatar
Default Re: need help picking cam shafts!!!!
Search, theres many ways to build your motor.
Old Oct 12, 2010 | 11:59 AM
elliott_holtGSR's Avatar
a bigger cam shaft is a good way to make power, but there is more to it then to just throw it in and call it good. most after market cam shafts require better springs and retainers in the head in order to hold the bigger lobe from you upgraded cam shafts. You should start off with getting an intake, header and exhuast and go from there. they are easy to install and will give you good bang for the buck! from there you can start to look at what options there are for your motor!
integra gsr96
Apr 13, 2008 05:12 PM
hytec
Nov 25, 2005 08:55 PM
.Unknown.
33
Feb 19, 2005 05:44 PM
