Just picked up a 92 DA Teggy OBD1
Hi HT i just picked up a 92 Teggy shell the car is pretty clean. I have a B16A OBD0 from my rexy before. Can i get some help with converting the engine over to obd1. Mostly wiring help or ideas. Most help needed is wiring harness options if any other than just a OBD1 DA harness, Dizzy options, and ECU options. All help is greatly appreciated. THANKS HT
You need to convert the car to obd0, not convert the engine to obd1. Buy a book at Autozone called "Honda Motor Swaps" it'll tell you everything you need to know. And they even use a b16 in the 90-93 integra section so it really shows what YOU need.
