94 honda civic EX auto tranny has trouble shifting?
when i accel. all that happens is the rpms go wayyy up and it wont shift till i let off the gas and it takes forever to get up to 3rd gear !!
also latley its been eating up gas way too fast does anyone have any suggestions ?
Thanks for anything you can come up with !!
also latley its been eating up gas way too fast does anyone have any suggestions ? Thanks for anything you can come up with !!
Sounds like the transmission is slipping, you might want to adjust the kickdown cable first though, sometime they'll cause some weird issues if they aren't adjusted right.
when i press in the gas the rpm will only increase it will not downshift and go
does that sound like a kick down cable problem? if so could you tell me where the kickdown cable is ?
it sounds like it is definitely having clutch problems, and there is not an easy fix for that with an auto besides find a cheap replacement!
billy barker
Apr 6, 2013 07:33 PM
