BLOX CAMS
I have oem itr flywheel
msd kit
head worked
60mm exhaust line
NGK Spark Plugs cable power cable
ECU programmed
4-2-1 vibrant collectors
68mm collectors obxr
trotle body 68mm
which blox is advisable to take power throughout the rpm
I am undecided for the blox type b and type c
staff said that the blox c are like the Jun 3,
blox band as like sk2 stage2.
these two which would be best for me as I ride a kit of high-compression pistons 82mm. ect~.
i am from portugal
i am from portugal
You need to tell more information about youre set up and then people on here will tell you what will work the best with youre set up.
Pretty sure Blox cams are made in the same warehouse in Taiwan as Skunk's cams are made...why the specs are very very similar, if not the same. I mean come one, they have P1's...not like they're direct copies of Pro 1's or anything...
port polish anda worked head
mainfol 68mm
trotle body 68mm
flyweel oem itr
kit msd
ecu tuning
4-2-1 vibrant
exhaust line home made 60mm inlet
ngk power cables
piston kit 82mm higth compression
bmc cda
ngk iridium sparck plugs
dual valve springs supertech
This statement isn't true and is an example of the misinformation that has been passed around for some time and put to rest a while ago. The Blox P1's were copied from the Skunk pro 1 prototypes that had poor centerlines and had idle problems. Skunk produced the pro 1's with that corrected, Blox did not so their cams have those same old problems.
i have a b16a2
mainfol 68mm
trotle body 68mm
flyweel oem itr
kit msd
ecu tuning
4-2-1 vibrant
ngk power cables
bmc cda
mainfol 68mm
trotle body 68mm
flyweel oem itr
kit msd
ecu tuning
4-2-1 vibrant
ngk power cables
bmc cda
