mini-me - Do I use a D15 or D16 head gasket?
Old Oct 10, 2010 | 04:15 AM
SoFresh1189's Avatar
Default mini-me - Do I use a D15 or D16 head gasket?
do i use the 1.5 head gasket or the 1.6 head gasket? or are they interchangeable?
Old Oct 10, 2010 | 05:21 AM
Default Re: mini-me question
ttt
Old Oct 10, 2010 | 05:24 AM
vansxskater's Avatar
They are interchangeable, it seems like a lot of people go with the d16y8 headgasket. It's really not that hard to find that info out on google or even this forum.
Old Oct 10, 2010 | 08:48 AM
send2artem's Avatar
go with the 1.6 they are like 29% at carquest auto parts
Old Oct 10, 2010 | 12:11 PM
had to go with the 1.5 because it was cheaper. $18 opposed to 35 and seeing *** theyre interchangeable i dont see any prob. goin at it hopefully all goes well. thanks guys
Old Oct 10, 2010 | 02:25 PM
Sr420Det's Avatar
well the 18 buck one is a graphite, u should b buyin the 35 which is a three layer metal gasket. The graphite ones are like cardboard and they suck, take it back and get the metal one.
Old Oct 10, 2010 | 02:57 PM
hatchaddict01's Avatar
^agreed 18 buck and blows in a month or 35 bucks and last years your choice
Old Oct 10, 2010 | 08:42 PM
hillssol95's Avatar
agreed x2 the layered metal are 100% better
Old Oct 11, 2010 | 04:49 AM
umm. well its a little too late for that, its already on the car... but now i kno for next time, or if the head gasket blows in a month
Old Oct 11, 2010 | 07:50 AM
hillssol95's Avatar
just remember to keep an eye on it, and that it might cause problems at some point.
Old Oct 11, 2010 | 06:33 PM
Default Re: mini-me - Do I use a D15 or D16 head gasket?
ok thanks. i might end up replacing the head gasket with the good one anyway.. i didnt have a torque wrench handy at the time so i just tightened the head studs as tight as i could and its leaking oil tremendously. i now have a torque wrench so tomorrow im going to tighten it to specs and if it still leaks ill replace it, if not ill keep a very close eye on it.
Old Oct 12, 2010 | 08:59 AM
nvm that.. i dont think the head gasket was leaking. someone pointed out to me it was leaking out of the valve cover which is when i realized i forgot to put the valve cover gasket on lol
Old Oct 12, 2010 | 10:02 AM
another question. the head i have is fullyy built and the block is stock. for whatever reason after it warms up its idling around 400rpm and it usually stalls out. i have a stage 2 crower cam and most everything else is supertech internals.
anyone know what could cause the low idle?
Old Oct 12, 2010 | 11:56 AM
ozh_hawaiian's Avatar
wow, I would not be able to drive my car with piece of mind knowing that I didint torque down the head, you could have unecessarily warped the head. you are supposed to torque the head to certain specs, and in a certain sequence so there is equal pressure applied to the gasket, so it wont leak. when you put in a new one, go for the 3 layer metal Y8 gasket, I think its a little thinner that the d15 ones, so it will raise compression a tiny bit
Old Oct 12, 2010 | 12:05 PM
Sr420Det's Avatar
u dont have a tune, thats y ur idle sucks. Ul probably need more fuel at idle with a bigger cam like urs. I bolted heads on plenty of times with no torque wrench with no problems. The order u bolt it down though is extremely important, i do hope u did that correctly, if u didnt ud know by now
Old Oct 12, 2010 | 04:47 PM
im pretty sure its a vacuum leak in my fuel pressure regulator. the engine runs fine no oil leaks anymore.
Old May 3, 2012 | 02:05 AM
EF2SLOW's Avatar
Wow with a fully built head like that id definitely give it a little more respect
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
projectef
Aug 3, 2007 11:03 AM
da_33
Jan 11, 2007 11:12 AM
PhatBoy5015
Jun 19, 2006 12:44 PM
