ABS BREAKS!! PLEASE HELP!!
WHEN I STEP ON MY BREAKS IT MAKES A VACUUM NOISE..SIMILAR TO A VACCUM NOISE.. KIND OF LIKE A SKIPPING NOISE,.... AND THE VEHICLE WILL NOT STOP.. I DONT KNOW WHAT THE PROBLEM IS..
Do you feel the shake in the pedal or in the ster wheel. In the pedal then I would think along the lines of the rotors. In the wheel the I would look at the chassis.
Do you have fluid in the ABS reservoir?
Do you have fluid in your BMC?
How do your brake lines look? Rubber worn/leaky/greasy looking?
The car shaking while braking is usually due to warped rotors/bad pads. Replace both of these (I would just do all 4 brakes/rotors) And also have your alignment/tires checked.
yes i have fluid in both... and my brake lines look good.. i just dont know what the problem is.. and the sjaking part thanks for the reply im definitly gonna check on them rotors tomorrow..
and to HONBEER... ILL WRITE IN CAPS IF AND WHENEVER I WANT TO.. DONT COME UP IN HERE TELLIN ME HOW TO WRITE MY POSTS.. I SUGEST U MIND UR BUSINESS AND GO ABOUT.. IF YOU CANT GIVE ME ADVISE ABOUT MY CAR THEN MOVE ABOUT UR BUSINESS.... RUDENESS!!!!!!!!!!
Talking tall for a trial user. And this site is my business. Newbie. Go and play with your lincoln logs. Least your spelling half *** better now. You get a bronze star for that. You need to turn on your spell check. My 10 year old spells better than you. Keep talking, someday you'll say something intelligent! Nobody says that you are dumb. They just say you were sixteen years old before you learned how to wave good-bye.
sounds like a sticking piston on one wheel that dragging and causing the system to get unbalanced. His ABS is kicking in...that is why he's not stopping (or taking longer to stop, the ABS is modulating the pedal
Cliff notes: Sticking piston/ drum on one corner.
