anyone have pics of.....
Old Oct 9, 2010 | 10:02 PM
efjones9's Avatar
Default anyone have pics of.....
what u have to do to the coolant hoses when doing a mpfi swap? thanx
Old Oct 11, 2010 | 11:27 AM
efjones9's Avatar
Default Re: anyone have pics of.....
Or could anyone explain to me what the correct path is for the coolant hoses
Old Oct 11, 2010 | 01:02 PM
24TEN's Avatar
PHANTOM MENACE
Left side obviously
Old Oct 11, 2010 | 01:06 PM
efjones9's Avatar
perfect thanx!
Old Oct 11, 2010 | 01:11 PM
24TEN's Avatar
PHANTOM MENACE
No problem, the ends of the coolant lines should be self explanatory with everything else connected. If you can't figure it out I'll tell you where they go (I'm sure you'll figure it out though ).
Old Oct 11, 2010 | 02:04 PM
Fo-Do Fanatic's Avatar
There are only two hoses you need to change. The "U" shaped hose going from the thermostat housing into the intake mani and the EACV hose that goes from the water pipe in on the back of the block up to the EACV. That one just needs to be lengthened about 4 inches to be safe.
Edit: They're hose 7 and 5 on the left picture.
Old Oct 11, 2010 | 04:17 PM
efjones9's Avatar
aite thanx!
zdizzle
Mar 10, 2008 10:50 AM
boostedcivicsir
Feb 28, 2007 05:04 PM
92SleeperH23
Sep 2, 2005 05:55 PM
crxb20ed
Jan 5, 2005 12:22 PM
Prod
Sep 16, 2004 07:29 AM
