95 Civic starter doesnt crank
Hey i have a 95 civic ex 5sp. It has a d16z6. I drove the car every day and everything seemed to be fine. Then one day it just wouldn't start. The starter doesnt crank or click or anything. The car runs perfectly if i push start it so i thought it was the starter. I put in a new one and still nothing. Please help!!!
The Main Relay will click three times during the starting process. When problems arise, one of those clicks (usually the third) is missing. If you consistently hear/feel all three clicks, the Relay is fine. DO NOT REPLACE IT.
Turn ignition to ON (but not to START): Click 1
Check Engine light goes off: Click 2
You now turn the key to START: Click 3
checked your starter and power/grounds to it?
If the clutch switch is operating properly, I suspect you may have a bad battery or a bad ignition switch contact assembly. You may also have gotten a faulty remanufactured starter.
A main relay problem won't cause a no-crank, so ignore anyone who tells you to check that.
Whats the cluster interlock switch? And yesterday i was taking out my throttle cable and now when the key is to on the fuel pump doesnt turn on and the only lights that turn on in the dash are the brake and seatbelt ones? anyone know what happened?
make sure the starter ground wire is tight and dry. my car does this every day. my ground wire for my starter is a lil loose but i dont have tools rite now. lol if i move it around it will start. but when it doesnt work it clicks alot.
popthatclutch13
Sep 20, 2018 03:12 AM
xxOldschoolxx
12
Mar 23, 2013 05:38 PM
