aluminum radiator question
just wondering if its necessary to get a aluminum radiator even if my oem radiator works fine. the car is gonna be a daily driven mild b20vtec. im already planning on getting a slim fan mainly because im running the rmf rpe header and im gonna have clearence issues with the stock fan.
stock should be fine
i have seen b20v's daily driven with civic half rads
although i did get the fullsize mishimoto for my 91 DA and i think its a bit overkill but i do daily my car and run a/c all the time even in traffic in 100+ degree days and my guage never even moves past 1/3 of the way (where it always sits)
i think since aluminum rads are getting less expensive alll the time its cheap insurance especially if you have thousands wrapped up in a build
Dont want to start a new tread just for this.
Thanks
I actually daily a EF B20 and use the neukin radiator/fan/shroud with our slim fan. Its probably the best unit you can get out there, aluminum rad, slimfan mounted to awesome shroud with quick connect pins, and a slim fan from us with oem plug! a first ever! and only $250 i mean come on..
as long as your cooling system is in good shapes with no leaks, thermostat working properly a civic half rad should work just fine, more is always nice especially if you auto x or road race. Iv ran single core eg radiators on a 370whp ls-t and never had a overheating issue.
i actually drive a da so i have a full size da rad and since my motor isnt sleved it wont see road racing or auto crossing just a simple 11:1 pump gas daily b20v and im replacing all hoses thermostats and slim fan
You should be fine. I've seen a few e85 setups and some people don't even run fans since e85 burns so cool it doesn't get the motor hot like gasoline does.
Thats what i was tinking aswell. Hopefully i wont have to run a slim fan with the big tybe tri-y headers that ima run on the b20v. Keep it simple.
You should be fine. Just stick with the civic sized radiator and stock fan. I don't trust cheap slim fans lol. Had one die on me and my car overheated really bad cause I left it idling for awhile and didn't notice it until my friend asked why my fan wasn't on.
Thanks
I've been running a Del Sol rad (small neck) for a few years now with no problems. Ran it at a couple of track events in July without issue. 225hp/155Tq. I would think that a full width Integra rad would be the same if not better.
Thanks
almostboostedgsr
Jul 26, 2007 10:40 PM
