90 Accord AT info needed
I have a 90 Accord/automatic that needs a trans. I'm not having luck finding anything from 90-92. I found a couple on craigslist, one from a 94 (112k) and one from a 97 (131k) but both sellers didn't know if they would work in mine.
So my question is, how can I identify which trans is in mine, and how can I tell which one the donor vehicle has? I'm guessing that anything with the 2.2 is interchangeable but I'd rather hear it from someone who knows these cars.
Thanks.
Thanks.
Yes, you will be able to use the 94, im not so sure about the 97. Everything should go right in place, but if im correct, the mounts may be different and you will have to get the mounts the trannys came off of and bolt them on to your chassis.
billyrusa
Mar 31, 2009 04:51 AM
