bogging problem on civic 93 d15b
Old Oct 9, 2010 | 02:15 PM
chirby17's Avatar
Default bogging problem on civic 93 d15b
my car is bogging. it starts when i drive for a while, then wen i got home the car sounds really high like high idle. then wen i rev it its start to bogg like its struggling to get gas or somthing. then its dies, then i turn it on. i check the fuel injectors plug i took it out then it doesnt feel like its about to die but the other three does. its the first cylinder starting on the right. i dont kno if it have to do with this but smokes comes out of my tail pipe like blue or white smoke.i cant tell. and i check the spark plugs it does the same thing. but wen i start it up wen its coool and i take off the plugs and the fuel injectors plug (not the same time) then it acts normal, like its about to die but the other three feels like its about to die more. please help thanks
Old Oct 9, 2010 | 03:40 PM
LSBoostedEk's Avatar
Default Re: bogging problem on civic 93 d15b
if you are seeing white smoke, that usually means your headgasket needs replacing. check your coolant for oil and check your dipstick or valve cover to see if any water is mixing with the oil.
Old Oct 9, 2010 | 08:46 PM
chirby17's Avatar
ttt. i need help still
Old Oct 10, 2010 | 06:39 AM
chirby17's Avatar
help
Old Oct 10, 2010 | 06:56 AM
chirby17's Avatar
thanks,i change spark plug, fuel filter, oil change, still nothing. it happens once a while tho. but once i start up the engine it feels like it bout to die, like wen i press gas gotta keep preessing to make go or rev, thats wen i start it up, but wen its warm up its fine like i dont gotta keep pressin it.
Old Oct 10, 2010 | 07:50 AM
chirby17's Avatar
any oneeE?
Old Oct 10, 2010 | 11:09 AM
chirby17's Avatar
any one?
prodjay10
Honda Civic (2001 - 2005)
Sep 17, 2016 01:18 AM
00hondasi
Mar 1, 2012 07:36 PM
TAZNGOOFY
Oct 28, 2010 07:13 PM
freddysEF
Nov 21, 2007 03:54 PM
I3ackfire
22
May 14, 2004 09:50 AM
