looking to do a s2k brake upgrade for a 93 si hb
I want to do a s2000 brake set up while staying 4x 100 front and rear calipers.. and s2k rotor sizes.. what parts I need to get this started...
http://www.b20vtec.com/forums/suspen...pplicable.html
Do not mind the fact that it says EK because it applies to the 92-95 Civic and DC integra as and in some cases the EFs but....
Why would you need the s2000 rear size? You wont need that size with its calipers either to upgrade the rears. Too strong. If you want to upgrade the rears trust me when i say the 02-03 EP3 with the 4x100 pattern already, with its 10.2" rotors and caliper about the same size as the s2k (which dwarfs the 713CLPS stock calipers), is plenty strong for the EK/DC/EG/EF and actually compliments the 11.8 fronts of the s2k/rsx-s, while being a lot cheaper (you'll need a custom bracket and redrilled 11.1" to rock the s2k rears, according to that chart in the link) Youll need a bigger MC and a 4040 rear prop valve as well (These wont apply if you have a car equipped with rear discs and/or a 1" MC already)
Why would i suggest this? Because i have the s2k/rsx-s 11.8 front and 02-03 EP3 rear 10.2 setup with Hawk pads with RE-11 tires. let me tell you- even with a full interior Del Sol it outbrakes everything ive ran into (not that i care) and i can brake super late into a turn, off of expressways and so forth. Others in this forum can also tell you about the fact you can hear the car hauling down from speed (which for me it hauls down VERY quickly) It eliminates the whole "Oh sh** i almost hit it" feeling. But if thats what you want, to each his own
