bench test relay
Old Oct 9, 2010 | 09:10 AM
Melvinsmellvin's Avatar
Default bench test relay
Hi, I am new to the forum. Would like to know how to bench test the main relay (RZ-0088) on my 1994 Honda Accord LX. Fuel pump does not seem to be running while ignition switch is in run position. Thanks for any help.
Old Oct 9, 2010 | 09:21 AM
redbull-1's Avatar
Default Re: bench test relay
See link for info. on main relay:
http://techauto.awardspace.com/mainrelay.html
Old Oct 9, 2010 | 09:39 AM
Thanks for the link, however after trying three times a can't seem to get it to open.
Old Oct 9, 2010 | 09:55 AM
redbull-1's Avatar
Do you mean opening the relay? I remember just lightly prying each side and using the screwdriver tip to pull the inner plastic up a little on each side until it came out. For example, pry one side pull the plastic up a little, pry the other side and pull up, and go back to the other side and repeat until it comes out.
Old Oct 9, 2010 | 10:04 AM
I can't get the link you posted to open. thank you
Old Oct 9, 2010 | 10:17 AM
redbull-1's Avatar
Maybe your browser or browser settings?
Old Oct 9, 2010 | 10:49 AM
Not sure why I've been unable to open link. I suppose i would have to go to another forum to figure that one out. I called a friend and he opened the link on his computer, then copied and pasted it to email. I have looked it over and it seems to have what I need. Thanks for the help. Hope you have a good day. thanks again
Old Oct 9, 2010 | 10:51 AM
redbull-1's Avatar
No problem. You also have a good day.
SIMJ
Mar 3, 2012 09:14 PM
Mr.Speed
Dec 19, 2008 01:07 PM
PSwagon
Jul 5, 2007 06:16 PM
90crxdxb16
26
Nov 9, 2006 07:31 AM
