slipping into 3rd
Old Oct 9, 2010 | 06:50 AM
singlecamsaint's Avatar
Default slipping into 3rd
i have a 92 accord 4 dr auto, its got a f22a. the problem is on the upshift from 2nd to 3rd with anymore than 1/4 throttle it will want to slip a little during the shift and rev up. i was wondering if its losing 3rd or if maybe the solenoids getting lazy. the car has 267k miles on it
Old Oct 9, 2010 | 07:29 AM
chiautorepair's Avatar
Default Re: slipping into 3rd
you need a trans, plain and simple
Old Oct 10, 2010 | 06:35 AM
i respectfully disagree, i changed the fluid, cleaned up the solenoids and adjusted the cable to the tb and now it shifts fine, execpt now OD goes in and out but i can deal with that
Old Oct 11, 2010 | 07:41 AM
joe_accord23's Avatar
new clutch and/or flywheel, when the clutch wears out it no longer has the padding to make the contact with the flywheel, and/or flywheels metal surface could be worn out thus not having the metal thickness to make contact with the padding. with 267k theres a high chance it could be this issue.
Old Oct 11, 2010 | 11:32 AM
chikin pickle's Avatar
Actually there is no chance that it is this issue. Seeing as automatic transmissions do not have a clutch or flywheel.
Old Oct 12, 2010 | 11:11 AM
holmesnmanny's Avatar
They do not have a clutch, they have clutches, but no flywheel.
B_Swapped93
Apr 4, 2013 06:30 PM
bombjester
Jan 27, 2010 03:19 PM
broke91hatch
Aug 6, 2007 10:39 AM
96b18c
Mar 2, 2006 01:54 PM
BigBadBuford
Oct 22, 2003 08:34 AM
