Garage Cleanout!! Integra Civic Prelude S2000 Parts, Something 4 Everyone Thread 1
P06 Single Cam Wiring Harness, One Damaged Wire $25
DA EF Rear Sway Bar, Aftermarket (Unknown Brand) $25
P14 Prelude Upper Timing Belt Cover $5
PR3 B16 Lower T-Belt Cover $5
09 Mitsubishi Lancer OEM Rockford Fosgate Woofer $20
West Coast Customer by Orion 12" Woofer (a little dirty) $30
92-93 B17 GSR Intake Manifold Bare $25
2009 Honda Civic SI K20 Shifter Box With Cables & Trans Brackets/Clips $150
Generic EF EG EK DA DC Front Strut Bar $10
2007 Civic Si Shifter Boot $10
209 Honda Civic SI Shifter Boot With Red Stitch $15
B-Series TB $10
B-series TB $10
B-Series TB's, Make one out of 2 $10 for the pair
D15 non vtec TB 96 Civic DX $10
AP1 S2k Steering Wheel $25
B18 P72 Aluminum Block to Trans Bracket $10
B16 B18 Steel Block to Trans Bracket $5
B17 Oil Cooler With Bolt $15
B-Series TB $10
B-series TB $10
H23 Head Bolts $10
S2000 Rear Differential Brackets/Mounts (2 Sets Avail) $50 each set
92-96 Prelude Rear Brake Rotors, Drilled& Slotted (Brand New) $20
Test Pipe $20
2007 Civic SI K20 Axles, Set $100 (will clean rust off b4 ship)
New AEM Air Bypass $15
Test Pipe $20
H23 Oil Cooler/Bolt $10
1990 JDM B16 Cylinder Head, Scored Journals, Good For Parts $50
D17 Full Gasket Kit, New $25
99-00 Civic SI B16 Cylinder Head, With Cams $200
2001 Honda S2k Engine Wiring Harness
OP you have entirely too many threads open. please read the sticky thread atop this foruim. i have merged the five latest into one.
thanks dude.
thanks dude.
Nice put together thread
i will take the aem intake and bypass.... does the good b16 head come with cover/solinod ect?
crdcz03
Oct 2, 2007 08:21 PM
