Sleeved GSR B18C1 block
I have a 1997 Darton open deck sleeved GSR block. Comes with matching oem main caps, main girdle and oem bolts. It's bore is at 84.5mm. Deck is in great shape, cylinder walls may need a hone to ensure new piston rings will seal. Work was done by Dave Hiatt Machine in Clovis Ca. Asking $700 plus shipping. For an extra $75 I will include an oem oil pan, barely used OEM oil pump (less than 1200 miles) brand new arp main studs and a brand new Golden Eagle oil squirter plug kit (over $200 value). The sleeves and machine work alone were over $1,000, and a bare GSR block can run as much as $200. Get a sleeved block now for almost half off, build yourself a sleeper 2.0L or a bad a$$ FI build. PM me your cell phone # if you want more pics, I can text them to you, or to let me know when you are ready to buy.
