b18a1 bubbling
I just did a headgasket and it runs great and all but the radiator bubbles and makes a bubbleing sound when you turn the car off after a 20 min drive. Its not overheating but at stops it starts to heat up but not much still under half way..my fan isn't working right now (project mode lol). I didn't get the head milled because it checked out good with my diy flat edge and feeler gauge test. could the block be warped or any idea of what I might be looking at. As of now I'm thinking about tearing it all back apart but I though id get some opinions. Thanks
Sounds like your coolant system is not properly sealed and keeping pressure.. I had this problem on my eg and i found out that my radiator cap wasnt sealing the coolant system properly.. I replaced it and it went away.
Sounds like a small HG leak, but make sure coolant system is completely purged.
Once purged, and your sure it is purged] if bubbles continue it is a good bet you have a small HG leak, either from a warped head, block deck or maybe just an improperly installed gasket.
Overheating when stopped with a non-working rad fan is normal.
I would drain and flush the system, put in new coolant, fire up the engine and then test the coolant for HCs, [hydrocarbon] and do a pressure test, it is less work then pulling the head again and it will give you an idea of what may be wrong. 94
I just fixed the same problem with my GSR. After all dancing around the hood, found all those gallons of coolant inside the car. So check under your mats if there is any fluid.
Also, if your oil is normal color and there is no smoke following you while driving, then its just leaking out somewhere. Check the hoses and stuff. Good luck!
How were they ending up in your car, that's crazy? And the funny thing is there's never a cloud of smoke. I just top it off drive a few miles like normal and then the thing starts to heat up, when I check its almost all gone and it sounds like there's a bubble machine going on inside the motor lol. Tommmorows my Friday so I'm going to take a deeper lookinto it and ill update, thanks for the input!
Anyways, thats a huge amount you're leaking somewhere. Can't be not noticeable if its not burning or leaking inside the car.
Waiting for the update tomorrow
runwitme
14
May 17, 2009 04:16 PM
WestEM1
Sep 23, 2005 08:34 AM
