Slimfan.com Offering you slim fans with oem plugs for radiators and more!
If you need slim fans we can help! We are the first in the industry to be offering slim fans with the oem plugs. I see the SPAL 13" is popular, i will be adding that to our lineup as we build our store up. Thanks guys! http://www.slimfan.com
Only $54.99 for this direct fit 1000cfm fan below. We will see if we can offer the high power 13" SPAL with the oem clips for about $130.
Neukin offers this impressive setup for only $250! Just released with the shroud, which is pretty cool.
Here are some pictures of the new shroud we offer, and you can order it with a fan and save some money. Here is another with the fuse inline ready to install, nothing needed to do by you.
Ill try to be around all weekend to help you guys out. Thanks and we are glad to be on Honda-Tech.
Was gona purchase but you guys are charging 25.60 for shipping to 08012, anything you could do about that? Im looking at your 94-01 integra slim fan in 12".
Thanks haha need to start somewhere.
Already talked with SPAL direct and waiting on some 30102044 13" High Performance units to come. They will be on the site shortly, ill pm you when they come.
Thanks guys!
Thanks guys!
94allmotor - if you want to hold off, ill have SPAL units that are 1700cfm in, 13" that one you are talking about is a Maradyne, good but for the same about price you can have better. Just let me know.
SPAL 13" 1700cfm 3.39 thick 21-23amps $130
Maradyne 12" 1500cfm 3.32 thick 13-15amps $120
Thanks
Thanks
Thanks
Thanks
Thanks
They are shipped out like factory to be mounted on engine side of the radiator to pull air through the radiator. If you wanted to use on front of car to push air through the radiator you would have to unbolt the blade and turn around.. then swap the pins on the harness.
Thanks keep the orders coming, dont forget to get FREE shipping with that code above. Let us know if you need anything else.
Do you have interest in a 12" fan mounted to a shroud you can attach to your radiator? $120?
if you can design something that will eliminate the need for me to use the zipties through he radiator and mount this thing in the stock location, maybe, but i still have a tight clearance with the b series narrow header
I ordered one and got it pretty damn fast.The box was so light I thought it might have been empty. Had it installed in less than 20 minutes thanks to the OEM plug pre-installed on the fan (I hate, hate, H-A-T-E having to cut and splice wires.). I didn't have to fully remove the rad either. Just removed old fan, disconnected the top hose (you'll get some spillage), tilted it out a few inches, installed the mounting kit & done.
Thanks guys.
YES we can offer a shroud that mounts to the stock fan mount points with ease. The slim or half sized radiator fan shroud is only 9/16th thick so that would only bump the fan towards the motor 9/16 ths of a inch.
NEW! We are now integrating a fuse holder into all slim fans so they are protected out of the box. A 15amp fuse in included too. This also allows us to give you a warranty.
Its 9/16th thick and mounts against the radiator hopefully squeezing between the upper and lower "cores" of the radiator. 13 7/8 wide 13 11/16 tall There are alot of radiator types out there and this should be just right for all of them.
We have 10" and can get some 8" instock if you need for intercooler, transmission cooler or air to water intercooler radiator. Check out the site. Thanks guys
