mysterious smoker
Old Oct 8, 2010 | 04:06 PM
joe busta's Avatar
Default mysterious smoker
so i bought an 95 integra ls non vtech and 2 weeks after my water pump went out so i changed it and while i was at it i changed the timing belt but now it smokes blueish white first it was only wen i went up hill but now its wen im stoped i did a compresion and a back compresion test and i cant figure out whats wrong can someone give me some advice
Old Oct 8, 2010 | 05:17 PM
civicStyle's Avatar
Default Re: mysterious smoker
just because a engines compression is okay doesnt mean it wont burn oil. to verify if you have blow by/ oil getting into your combustion chamber. you need to do a leak down test, that will tell you what percentage of leaking you have per cylinder. another quick thing you can do is make sure your pcv valve isnt stuck. i hope some of this info helped
Old Oct 9, 2010 | 11:28 AM
Rickdogg's Avatar
how can u tell if the pcv valve is no good?
Old Oct 9, 2010 | 03:07 PM
Ryan_dc2's Avatar
I'd check the head gasket after I make sure the oil rings on the pistons were still good.
Old Oct 16, 2010 | 12:04 PM
joe busta's Avatar
i checked my pcv and it had 2 for somereson but i replaced both andit stoped smoking but im still going to do those test thank you
94_DC
Jun 15, 2012 02:13 PM
bvillarreal
Jan 24, 2012 02:39 PM
parkerjamison
Sep 11, 2008 07:32 PM
90teg91hatch
Jun 25, 2008 03:46 PM
Jet Black
Jul 22, 2003 07:41 AM
