89 DX Hatch w/ B8 block and B7/2 head idle problems
Old Oct 8, 2010 | 02:27 PM
ih8sndq's Avatar
Default 89 DX Hatch w/ B8 block and B7/2 head idle problems
I picked up a 89 DX hatch with a B8 block and a b2/b7 head, still dpfi. First, I have adjusted the valves and checked the timing, and everything seemed spot on. I have also tried multiple iacv's and injectors.
The problem with the car is, as soon as you start it, the rpm goes to almost 2000 and white smoke comes from the exhaust. I am completely baffled as to what the problem is. I have a fear that some valves are dead but I keep telling myself that it is something else. Any help would be greatly appreciated.
Also, I understand that some of the B8's didn't have valve reliefs, but I haven't look into the cylinder to check.
Old Oct 11, 2010 | 04:32 AM
ih8sndq's Avatar
Default Re: 89 DX Hatch w/ B8 block and B7/2 head idle problems
Does anyone have any ideas?
Old Oct 11, 2010 | 04:52 AM
Jockone's Avatar
Compression test will tell if valves are dead.
White smoke sounds like head gasket problem but it might just be condensation if the car has not been run for a while.
Old Oct 11, 2010 | 07:16 AM
ih8sndq's Avatar
I did a compression test and all the cylinders were in the 180's. What could be the cause for the crazy high idle?
black teg
Dec 4, 2013 10:29 AM
Tru
Jan 10, 2007 04:49 PM
thad
Mar 26, 2004 07:47 PM
1fast5gp
Mar 22, 2003 01:58 PM
