obd0 pr3 question help!!
i have a 90 si wiring in the vtec using a pr3 so when u wire in the vtec do u splice in? or do u cut the wire a at the ecu plug ?and add a wire and run it to the solenoid or pressure switch or knock sensor i spliced in and im gettin a knock sensor code i was wondering if it had anything to do cause i spliced in any help is appreciated
ahthisguyhere
11
Apr 24, 2006 04:22 AM
