stock intake piping upgrade :)
Old Oct 8, 2010 | 08:26 AM
redef90si's Avatar
Default stock intake piping upgrade :)
Most of you will think I'm a geek for looking into this but I'm all about $ per HP.I recently decided to see how much bigger a 94-01 integra's stock intake piping was than a stock 88-91 civic. These were the results.
INTEGRA 2.5/8" at the throttlebody
CIVIC 2.1/2" at the throttlebody
The integra has roughly 5% bigger inlet
INTEGRA 3.1/2" at the filter end
CIVIC 2.7/8" at the filter end
The integra has roughly 18% bigger outlet
So from my findings just by upgrading to a B series intake piping it would allow your motor roughly 15-20% more air flow.Hope this helps someone.The way I think about it is for $10 to Have a little upgrade like this might help a few people out there.Let me know what you guys think of my "findings" Matt
top intake piping is from the 94-01 integra,bottom piping is from a 88-91 civic.
Old Oct 8, 2010 | 08:31 AM
munchies91crx's Avatar
Default Re: stock intake piping upgrade :)
haha just go with aem cold air. but nice find buddy.
Old Oct 8, 2010 | 08:40 AM
redef90si's Avatar
Ya AEM cold air is nice But we get a ton of Rain in British columbia and I don't want to hydrolock my motor lol.I know you can buy a bypass valve for $50 or so but $200-300 for an intake seems a little steep to me
Old Oct 8, 2010 | 08:44 AM
didnt even notice u were in bc haha. and its a good find dont worry id never put on a cold air. im sketch bout them haha. so is it easy for u to source parts up there?
Old Oct 8, 2010 | 08:48 AM
redef90si's Avatar
Sent you a Pm.
Old Oct 29, 2010 | 02:57 PM
redef90si's Avatar
bump
Old Oct 29, 2010 | 03:13 PM
jdm ef8 89's Avatar
It sounds like it would be nice if you had a d16z6 intake manifold bored to fit an LS throttle body and then throw this on there. Im all for cheap HP gains. good job
Old Nov 2, 2010 | 07:12 AM
redef90si's Avatar
thx
Old Nov 2, 2010 | 07:28 AM
Todd00's Avatar
I said I don't want a title!
Right, and the one from the Integra Type R is even larger. But...have you tried to hook this to the OEM airbox yet? Or were you going to ghetto-fab a universal K&N on the end or something?
The OEM 88-91 airbox doesn't really flow all that well in stock form. I've ran a modified airbox and gotten much better performance, but that's still not as good as an open element filter.
I honestly don't see the point of this post other than telling us that the Integra has larger intake piping diameter (which most of us will probably already know).
Old Nov 2, 2010 | 08:06 AM
efjones9's Avatar
i dont think it will fit unless u relocate the batt in our poor ef's but this could be 10xs better with a full intake system.....u can go with a ls/gsr/type (r whatever u want) throttle body and use the intake arm and airbox from a 95 gsr (cone filter type) and baam better flow with oem parts
Old Nov 2, 2010 | 08:10 AM
civic nation's Avatar
I already did this mod unstead of buying a crx sir intake . but I have my battery relocated and I had to shave down my stock airbox .
Old Nov 2, 2010 | 08:39 AM
lunalink's Avatar
I used a stock B16A2 intake pipe with the stock air box all OEM
No need to buy a PM6 tube
( I had the tube from a previous swap )
Old Nov 2, 2010 | 09:06 AM
Deetz's Avatar
Crazy Honda Guy
I spent $45 an just bought a whole oem EF8 airbox and intake tube setup, which is definitely beefier than the stock usdm intake setup.
I am not a fan of cai systems
Old Nov 2, 2010 | 10:38 AM
crx_si-r's Avatar
I agree with deetz. I have a jdm b16 intake set up and it's still berried than any aem intake.
Old Nov 2, 2010 | 07:07 PM
redef90si's Avatar
I would relocate the battery yes;the point of the thread was to help people out that didn't know.I would also use the dc(94-01) stock air box,Matt
Old Nov 2, 2010 | 07:42 PM
89LSED's Avatar
I made an LS stock air box fit. Cut the bottom of it off, and massaged the fender well a bit, looked nice and stock!
Old Nov 2, 2010 | 07:45 PM
jdm ef8 89's Avatar
It would be perfect for me because the battery in the trunk and it would also look nice under the hood.
Old Nov 3, 2010 | 07:48 AM
redef90si's Avatar
glad to hear.
Old Nov 3, 2010 | 08:20 AM
Tyson's Avatar
just replace the stock intake with some 3" ducting. no ribs to slow the air down. still use the stock airbox with a K&N filter. using the lower part of the air box is optional.
the airbox nipple is 3" already. shape the ducting to the same stock intake pipe. cover with duct tape. hose clamp to TB.
the only issue youll have is needing to make a catch can breather because you lose the vent and vacuum hose from the intake to the valve cover. not a big deal if you were planning on doing that anyway, so its overall a cleaner setup.
Old Nov 3, 2010 | 08:28 AM
redef90si's Avatar
another good idea.
Old Nov 3, 2010 | 03:25 PM
89LSED's Avatar
Her ya go bro,
that pix you requested.
B16 In an EF Sedan.
LS intake piping
LS air box, Cut the bottom of the air box to only an inch blow the clamps, put in a K&N and that baby was LOUD!!!
Old Nov 3, 2010 | 03:27 PM
89LSED's Avatar
dang you! Now that I'm going through my 4 door pictures I'm starting to miss it again!!
Grrrrr. HAHAH
Old Nov 3, 2010 | 04:03 PM
redef90si's Avatar
Grrrrr. HAHAH
lol Thanks a lot man;I'm going to try that on my buddies Ef.Thanks again for the pictures.
redef90si
16
Dec 25, 2012 03:48 AM
playahwitgame
Sep 11, 2006 05:21 PM
Charlie Moua
Sep 8, 2005 04:20 PM
ThePro
Sep 27, 2004 05:50 PM
cornholioEK
Jan 20, 2003 05:48 PM
