FS: H23 VTEC SETUP H23/H22 TYPE R HEAD *$700* (714)
2000 Euro Type-R H22 Head (OEM TYPE R PORT & POLISH SUPER CLEAN!!)
includes cams, valvetrain, cam caps, and everything..
H23A1 Short Block (Very slight minor scratched lines, needs to bored & honed to new piston spec which is .5mm over)
Comes with ALL NEW:
H22A1 87.5MM Vtec Pistons w/ Pins
ACL Bearing Kit
ARP Rod Bolts Kit
H23A1 Rods
H23A1 Crank (Newer;Good Condition)
Basically just need to be bored & honed to spec for the installation to it's new .5mm over pistons!! Was quoted about $300 to bore, hone & micropolish/balanced the newer h23 crank from RS Machines! Looking to get just $700 FOR THE WHOLE SETUP!! The head is worth that much alone easy! Hate to see it go.. was going to do my H23 H2B VTEC setup. Just moved out of state.. everything has to go! Give me a call at (714) 363-7042. Everything is in VERY GOOD CONDITION. No dirty shitt.. very clean!! Thanks!!
Comes with ALL NEW:
ACL Bearing Kit
ARP Rod Bolts Kit
H23A1 Rods
trooper0641
Sep 29, 2010 12:52 PM
trooper0641
Sep 15, 2010 11:01 AM
