How far should sunroof drain hose stick out from the body?
Old Oct 8, 2010 | 04:40 AM
cjw_89's Avatar
Default How far should sunroof drain hose stick out from the body?
So its my first si civic and i have a sunroof drain leak.I had a previous post, but i just want to know how far the drain should stick out off the body. I double checked the hose and it was cut with a knife on ecu's end.I was wondering maybe where it was cut it wasn't sticking out quite enough to remove all the water.I hauled the hose up through the a pillar and poured water where the leak was before and water poured out through the hose fine with no water dripping by the ecu.So its definately my problem.
And another thing if i removed my fender liner on the passenger side can i see where the drain exits?? Thanks in advance.I ready to lay down some bedliner on my floors to seal them up but this is holding me up majorly!
nbcivic
Mar 14, 2010 06:43 PM
joelmatt89
21
Apr 15, 2009 06:16 PM
Robstunner4
Nov 1, 2006 07:27 PM
vietkangta
May 17, 2006 08:28 PM
JTCdudeman
Feb 17, 2003 05:48 AM
