would i need a b16a injectors for my set-up?
looking to get rc 310 injectors
b16a head.
port&polished.
buddyclub spec III cams.
buddyclub retainers.
buddyclub valve springs.
skunk2 camgears.
hytech header
itr manifold/ str 68mm TB
b18c1 block.
ls crank/shot peened ls rods
ctr pistons.
b16a head.
port&polished.
skunk2 camgears.
hytech header
b18c1 block.
ctr pistons.
ok im guessing you are looking for somewhere around 200hp at the crank, so the 310s should be fine. but i will stress SHOULD, thats using a simple online calculator. so its not gonna hurt to go bigger. going a lil bigger ALSO can save you a lil bit of cost if you decide you want more power later.
Should be helpful...
http://www.rceng.com/technical.aspx
I'd say 310's should be fine for what you're doing as well. For sure upgrade from stock though.
I'm not trying to hate, but I doubt this build will make 200whp. And like mentioned above, stock injectors (maxed out) will support 200 whp.
Might not "need" it but why would you want to knowingly max out stock injectors? If you're building a motor just do it right and cover all the bases, its not like it's that much of an investment compared to the rest of the build.
I like 370-450cc injectors on all motor builds. 310's will work but id go with 360/370. This is all true of course ONLY if using a wideband/software/datalogging to tune with.
Angel4768
May 9, 2011 12:49 PM
Angel4768
Sep 26, 2010 05:17 PM
Angel4768
Jul 19, 2010 09:38 PM
