How move cruise control/power mirrors and locks from 92 LX sedan to 94 VX hatch?
Old Oct 8, 2010 | 03:29 AM
mjshealy's Avatar
Default How move cruise control/power mirrors and locks from 92 LX sedan to 94 VX hatch?
Hey all, I have a 94 vx hatch with a zc swap, no options. I have a 92 lx 4 door fully loaded. What could I do in terms of putting the cruise control, power mirrors, and 2 of the power door locks out of my 4 door and putting them in my hatch? Help is appreciated!
Old Oct 8, 2010 | 04:15 AM
cjw_89's Avatar
Default Re: need help with options swap on two civics
heres a faq for all but cruisehttps://honda-tech.com/forums/showthread.php?t=1065575
Theres not a whole lot about cruise that i could see.As for power locks,if you do master them you want to take the rear door handles off the 4 door and put them on your eg that would be cool.I seen someone talk about it before on this site.Same purpose just no key hole.
Old Oct 8, 2010 | 06:44 AM
Former User's Avatar
Default Re: How move cruise control/power mirrors and locks from 92 LX sedan to 94 VX hatch?
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Old Oct 8, 2010 | 08:29 AM
mjshealy's Avatar
Thank you cjw89 for the quick response... ill check that out when I get home from work, I'm only on my phone right now. And thanks ronj... I was in a hurry this morning and couldn't think of better wording at the time. I appreciate it guys!
Old Oct 8, 2010 | 09:15 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Quick breakdown:
-Cruise will swap no problem. See my DIY in my signature.
-Wiring harnesses will need to have their wiring for the power options stripped out but will work. Only change is to extend the wires to the lock actuator. See my DIY on this too.
-Mirror door mount bases from the 4dr will need to be swapped with the 2dr ones.
-Lock actuators from the 4dr won't transfer to the 2dr. The part where the wiring attaches (held on by 3-4 little screws) might swap, though - worth a try. You'll need the switch from an EX Coupe, though, and the door panel, unless you make your own holes.
Old Oct 8, 2010 | 09:20 AM
94EG8's Avatar
Seagull Management
Cruise control you can grab from the sedan, as well as the underdash harness and front door harnesses. You can't use the mirrors, 4 door are shaped differently than 2 door (you can use the switch though) For the doors you need switches and door panels from an EX coupe and window regulators for an EX coupe or '94 - '01 Integra 2 door.
See DeSchlong's writeup for more details:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/honda-civic-92-95-eg-eh-ej-oem-cruise-control-install-guide-%96-manual-transmission-2437528/#post36492981
Edit, hey never saw your post DeSchlong.
Old Oct 8, 2010 | 09:28 AM
deschlong's Avatar
Loved
Community Favorite
Yeah I noticed he wasn't asking about power windows, but good you covered that too. Note he can swap the mirror door bases and get power mirrors without buying all-new ones.
EDIT: Might be bad info - sorry.
Oh, that reminds me -
OP: You'll also need the mirror triangles from a 2/3-dr with power mirrors. 4dr won't fit.
Old Oct 8, 2010 | 09:31 AM
94EG8's Avatar
Seagull Management
Originally Posted by DeSchlong
Yeah I noticed he wasn't asking about power windows, but good you covered that too. Note he can swap the mirror door bases and get power mirrors without buying all-new ones. (Untested, but pretty sure since the mirror shells are same p/n for 2/3dr and 4dr)
I think you can, but the base needs to come from a 2/3dr with power mirrors. I know I tried to use a 4 door manual mirror base on a 2 door power mirror shell before and the 3 screw holes wouldn't line up.
sohcturbo92vx
Jan 19, 2012 05:44 PM
Built B16A
Jan 31, 2003 12:50 AM
