DC Clutch / Tranny question
Old Oct 7, 2010 | 11:49 PM
NFM_Dm's Avatar
Default DC Clutch / Tranny Problem HELP!
Let me start off by saying ive got a 94 dc with a LS motor and GSR Tranny.
Clutch died 2 months (Springs were popping out the disc) installed brand new flywheel and clutch for XTD stage 2 (Press plate, Kevlar disc, 10 lb flywheel, Throw out bearing, Pilot bearing, New Master and clutch slave.)
Now my question is will a bad input shaft bearing wear out a clutch faster? My car makes a nasty chattering noise when the clutch pedal is let out and the car is in neutral also makes kind of a grinding noise when I rev the car up (did this before i changed the clutch i thought it was a bad Throw out bearing). The chattering noise and and grinding noise are completely gone when i push the clutch pedal just a little bit in. The clutch is starting to slip a little say for instance im in 5th gear doing 20 and mash the gas it'll slip then catch and start acceling. (My car did not slip when I put the new clutch in and it was broken in properly).
Other known problems.
slight rattle/vibration in the shifter. (Brand new Energy motor mounts both front torque mounts)
when i push my clutch pedal to the floor the car wont go in gear rolls forward when i try, grinds syncro's when shifting gears
^ that problem dosnt happen when i push the clutch pedal halfway.
Any help would be much appreciated.
also does anyone know the part number for the input shaft bearing?
Old Oct 8, 2010 | 12:01 PM
NFM_Dm's Avatar
Default Re: DC Clutch / Tranny question
PLEASE HELP
Maybe i need to adjust my clutch pedal? when its in first gear and i let the pedal out it engages really late. (But this dosnt fix the grinding noise coming from the tranny and the chattering.
Old Oct 8, 2010 | 04:47 PM
NFM_Dm's Avatar
no one?! come on ht dont let me down ive searched and searched.
Old Oct 11, 2010 | 11:37 PM
NFM_Dm's Avatar
bamp
Old Oct 12, 2010 | 09:57 PM
NFM_Dm's Avatar
HALP
uVTECiVTEC
Jul 22, 2011 12:35 PM
mugen si
Apr 4, 2008 03:40 PM
Rhythmsnewsn
May 22, 2006 12:59 PM
garados
Dec 20, 2002 03:17 PM
Que
Jan 17, 2002 10:37 PM
