ef hatch j swap?
Old Oct 7, 2010 | 10:17 PM
chaggy's Avatar
Default ef hatch j swap?
Ok so my buddys looking into doing a j30 swap into his hatch. My questions are what's need to make this work in an ef? What's the expectations out of this build? Please lemme know asap to see if this is a possibilty for a nice whip.
Thanks
Old Oct 8, 2010 | 12:49 AM
haddowj's Avatar
Default Re: ef hatch j swap?
well its going to stick out of the hood alot. you could get the same results with the amount of money it'll cost you (him) with a B series.
but to your question. hasport makes mounts and im not sure what else youll need other than ecu trans and a custom hood of some kind of course.
for results there is an eg hatch where im from and it runs low 13's. i think his best time is a 12.9 witch is totally accomplishable with a b or d series and it wont stick out of the hood or throw of the cars weight distribution.
just my 2cents but id say its not worth the time, money, or effort needed to complete the swap. but props if it actually gets done because i can respect what it takes to get it done and its some what original... not just another B or D.
Old Oct 8, 2010 | 08:56 AM
CRX Toad's Avatar
Call HaSport talk with Chris.
Old Oct 8, 2010 | 10:30 AM
Hasport's Avatar
with the j-series swaps make sure you get the type with coil packs. distributor engines will not work.
a 6spd transmission along with shifter box and cables from 04-up TL or 03-up accord
the 6spd from a 03 cl type-s will work as well but there are bosses that need to be drilled and tapped
you will need a mount kit, axles, and wiring conversion
we carry the mount kit and axles
for the wiring conversion there are different places that make it and you can find them searching the net
the swap is a fun to drive swap with lots of torque
Old Oct 8, 2010 | 11:04 AM
CRX Toad's Avatar
Dang ESP HaSport
Old Oct 8, 2010 | 01:24 PM
96accordsir's Avatar
here is a local crx with it i saw last sunday at a show.
Old Oct 8, 2010 | 02:19 PM
JeffBro's Avatar
Thats one bad looking crx
Old Oct 9, 2010 | 05:36 AM
joeskyline06's Avatar
i believe that crx was in the newest or 2nd to newest edition of honda tuning, track down the issue and they have all the info on doing it into a crx, should be about the same. or at least a good place to start
Old Oct 9, 2010 | 08:27 AM
chaggy's Avatar
Alright well... I talk with my buddy and if he really wants to do this then well have a build thread started on this project
alarikshelley
Jun 25, 2015 08:44 PM
onlydrivesi
K Series
Oct 19, 2014 10:22 PM
thespecv
Jan 25, 2010 06:57 PM
EgChad253
Jun 6, 2008 07:03 AM
b17eg
Oct 14, 2007 02:05 PM
