ek gsr idle problems and weird noise
Old Oct 7, 2010 | 06:41 PM
ekcid97's Avatar
Default ek gsr idle problems and weird noise
there is a weird noise in my gead some people have told me i need to tighten up my valves but i dont noe and my car idle weird like gose from like 900rpms then up to like 1300rpm and when drivein when i stop it idles at like 2000rpms then i revv it a lil and it goes bak down to 900rpms soo i dont noe about that... and i jus found out i have a straight pipe and alot of black smoke is comein out like u cant see it unless i pik up speed alot but it gets all over the bak of my car seems like its runnin rich pleazzz help jus got the car good platform to start with first honda but been into this game for along time soo plezzz help anything jus post whatever u think will post a video if u guys can help me more pleazzzz help
Old Oct 7, 2010 | 07:45 PM
PyroProblem's Avatar
Default Re: ek gsr idle problems and weird noise
I saw this somewhere.
Lets eat Grandma!
Lets eat, Grandma!
Punctuation saves lives.
But seriously, this is going to be really hard to diagnose over the internet. I would take it straight to a certified Honda/Acura mechanic. It sounds like you have more than one problem with all the noises,idling issues, and black smoke...Good luck!
Old Oct 7, 2010 | 09:55 PM
ekcid97's Avatar
thanks man...illl get on that ..anymore advise plezz help..
Old Oct 8, 2010 | 02:51 AM
ekcid97's Avatar
does anyone else have any input it would help alot thanks
Old Oct 8, 2010 | 11:13 AM
ekcid97's Avatar
ok well the idle problems went away last night. i put a qort of oil in last night cuz i check and i was very low. and this morning i drovbe my car a bit and it was idleing at like 90orpms it was nice. and from what i found out the lil bit of smoke when i take off its from my straight pipe. so anymore info would help plez do
Old Oct 8, 2010 | 12:05 PM
ekcid97's Avatar
i have a ? what if i put a b16 head on my gsr block???? would that be a good thing?????
Old Oct 14, 2010 | 11:27 PM
dpacheco's Avatar
yea bro if yo are running with no CAT you are going to make the world black. is your car BAR'd?
Old Oct 15, 2010 | 12:02 AM
95skunkedgsr's Avatar
is that a trick ?
Old Oct 16, 2010 | 10:41 PM
ekcid97's Avatar
what does BAR'd mean.... dont hate new to the game...
Old Oct 18, 2010 | 12:59 AM
civicfd2's Avatar
BAR'd means is the engine match up with the car in other words if you do a engine change youmust bar the new engine to the car it involes takeing the car to CHP AND a smog check also running no cat in your car will make black smoke becouse your Oxygen sensor is reading bad and will tell the ECU WRONG which in turn is makeing your car run Rich
Old Oct 18, 2010 | 01:04 AM
civicfd2's Avatar
Also i would not run a B16 head on a gsr engine you will loose power One more thing is your Idle problame is most likely a vacume leak on you intake manifold to find a leak spray WD40 on the manifold while the car is running and if you see any bubbles theres your leak
Old Oct 18, 2010 | 10:08 AM
ekcid97's Avatar
thanks man, yea my car does run rich. i wanna get a cat back but if i did wouldent i loss power????
Old Oct 18, 2010 | 10:11 AM
ekcid97's Avatar
thanks,yea im stickin with my gsr head,cuz like this morning i started ,y car and the idle was at like 2000 then i revvved it a lil and it droped to like 900 then like 1200 then back down ect. then it jus stayed at 900
Old Oct 18, 2010 | 11:23 AM
ekcid97's Avatar
and is it good that im runnin 91 oct. in my car does that make it run more rich??
MVMBuyer
Honda S2000
Mar 29, 2017 04:05 PM
puresteez
Mar 31, 2014 07:48 PM
dorian7
Sep 3, 2013 11:48 AM
Honda-Ninja
Jul 13, 2010 03:29 AM
B204door
Sep 2, 2007 06:59 PM
