Solenoid gasket question
I have a 98 accord 4-cyl. with 199k. I am trying to replace the v-tec solenoid gasket, but the dealer says I have to buy the whole assembly. He says that Honda does not provide a v-tec solenoid gasket for a 1998 accord. They only have the filter screen (goes to head of engine) gasket. What the heck do you do? I need to replace this gasket only, not the whole assembly.
What solenoid are you talking about?
The VTEC spool valve gasket & filter is part number 15825-P0A-015 - $10.00
The rotary air control solenoid gasket is part number 36461-PAA-A01 - $14.00
If you took apart the VTEC solenoid, IIRC, that O-ring also comes with part number 15825-P0A-015
I'm looking for the v-tec gasket that sits inside the triangle housing and under the solenoid. It is called "solenoid gasket". I called several dealerships and they don't have/make this gasket for a 1998 accord 4-cyl. lx 4-door sedan. Can you look this up again?
Thanks for helping me, but that o-ring is very close but not exact. That part number is for a 95-96 accord not 1998. I have 36172-poa-005 in my hands now and compared it with original part and is slightly different. I tried using it, but a slight leak exists. Help me please!
The 98-02 VTEC solenoid wasn't designed to be taken apart by Honda techs. Therefore there is no listing for any solenoid base gasket for the F23 VTEC. You are correct, the one I posted above is for the 94-97 VTEC solenoid. Looks like RTV may be your friend.
Ah the V6 one looks a bit different than the 94-97 4 cylinder one.
Moi Zver' (GSR)
Dec 3, 2009 01:17 PM
Lightsped
Sep 1, 2009 08:40 AM
